Aircraft Projects
Date:  11-25-2007
Number of Hours:  4.00
Brief Description:  Elevators - 05 - Finished Priming, Adjust. Rod End
- Prepped and primed left elevator skin and trim tab.
- Built a tool to adjust the rod end bearings to the propper depth. I saw this home made tool on Scott Will's site (http://scott.jpainter.org/log/cat_empennage.html). He gives credit to another builder (Sam Buchanan) but the link is broken. This tool is awesome, easy to make and works well.
- Adjusted all elevator rod end bearings.
- Re-attached elevators to ensure all the clearances were still correct. Checked 4.0.
* OK, Couldn't help it...Put the VS & Rudder on to see how the tail looks all together. It looks like the empennage of an aircraft...
* WHAT'S LEFT TO DO:
- Need to adjust Rudder rod end bearings. After adjusting the elevators and seeing how many turns it took to get to 13/16" (or 26/32" on my ruler) and putting them on the VS it is apparent that they are way off.
- Looked for a sleeve to drill the elevator horns but without the bolt or bearing it was tough to find something that would work. Need to find something to drill the horns.
- Waiting on a 4" No hole yoke to rivet a few holes in the elevators and a dozen pop-rivets for the leading edges.
- So other than the fiberglass this would be it for the Empennage.
Both Elevators Primed.
Simple tool used to adjust rod end bearings. I'll add more details under tools.
This picture was a must.
