Brief Description: Trim Tab - 04 - Building Trim Tab
- Finished edges on trim tab skin. - Bent trailing edge to same dimensions as the left elevator trailing edge. - Clecoed together the assembly and attached the trim tab horns. - Final drilled the horns to the assembly and the bottom edge of the spar (E-607-PP) to the skin. - Attached the trim tab hinge and alligned it with the left elevator.
Drilling hinge to trim tab after aligning with elevator.
