Aircraft Projects
Date:  11-10-2007
Number of Hours:  1.50
Brief Description:  Trim Tab - 02 - Bending Tabs
- HAPPY BIRTHDAY DEVIL DOGS!!
- Created bending blocks for trim tab ends. They turned out to be too wide and didn't allow the tabs to overlap.
- Marked bend line on trim tab and applied carpet tape to hold blocks.
- Put bending blocks in trim tab and clamped to bench.
- Began to bend the tabs and realized despite all the planning and studying I was bending the wrong tab first. It actually was the correct tab to create a water shed to prevent water from rolling down the trim tab and into the part but the pilot holes to rivet the two halves together was wrong.
- I slightly bent the tab back and started bending the other side. It seemed to work at first but either I was missing the correct tab or hitting them both at the same time. I started to use the rivet gun with a mushroom bit and this did work until the bending block moved and messed up the part. The skin cracked and was bent in the wrong place...Ugghhhh!!!!!
- Ordered New Part from Van's. I needed some other stuff too (more MK-319-BS rivets, etc.), so no big deal.
- WHAT'S LEFT TO DO:
- ReDeburr new Elevator Trim Tab skin (when it comes in).
- ReFold trailing edge of Elevator Trim Tab skin.
- Recreate jigs to bend trim tab (The ones I made are too wide).
- Final drill and pop rivet trim tab.
- Drill spar, hinge and trim tab horns.
- Prep and prime parts.
- Attach trim tab to elevator.
Marked bend line (backed off 1/32
Marked bend line (backed off 1/32").
Put in a piece of double sided Carpet tape.
Clamped bending blocks into place.
