Brief Description: Vertical Stabilizer - 04 - VS Final Assembly
- Finished dimpling the VS skin (VS-801) - Attached the VS skin to the front VS spar assembly. - Riveted the front spar and center VS rib to the skin (VS-702 and 708 to 801). - Attached Rear VS spar and riveted the left side and both end ribs to the skin. - Started riveting the rear VS spar on the other side but did not finish. - About 30 to 40 minutes left to completion.
