Brief Description: Left Elevator - 07 - Rivetting Skin to Skeleton
SAME AS RIGHT SIDE: - Put ProSeal on the stiffener intersections (I hate this stuff). - Put 2 Rivets in the counterbalance skin and elevator skin. This prevents you from having to blind rivet these holes later. - Loosely installed counterbalance weight. - Put understructure in skin and clecoed. - Riveted skin to understructure. Still have 8 holes in the trailing edge that need rivetting. I also have a few on the trim tab spar. - Didn't rivet the top of the trim tab spar so I can attach the trim tab hinge, to align and final drill. - Also still need to install the little rib that was made.
