Aircraft Projects
Date:  11-6-2007
Number of Hours:  1.75
Brief Description:  Left Elevator - 05 - Riveted Understructure
- Riveted the left elevator end rib to the counterbalance rib (E-704 to E-705).
- Riveted the nutplate reinforcement plates to the left elevator spar (E-610-PP and E-611-PP to E-702).
- Riveted nutplates to the reinforcement plates and spar.
- Riveted the root rib (E-705) to the left elevator spar (E-702).
- Riveted the end rib and counterbalance rib to the elevator spar.
- Riveted the left elevator horn (WD-605-L) to the elevator spar and end rib.
* WHAT'S LEFT TO DO:
- Obtain some more pop rivets and place in trailing edge holes.
- Bend elevator skin on inboard area near trim tab.
- Put Proseal / RTV on the stiffener's intersection.
- Rivet the skin to the skeleton.
Riveted reinforcement plates and nutplates to Left Elevator spar.
Left Elevator understructure with ribs riveted on.
Riveted on Left Elevator Horn.
