Brief Description: Rudder - 06 - Finished Left Rudder Stiffeners
- Finished deburring and scuffing left rudder stiffners. - Dimpled holes in left rudder stiffeners. - Cleaned and prepped left rudder stiffeners. - Primed left rudder stiffeners. - Dimpled left rudder skin for stiffeners. - Fabricated bottom rudder tip attach strips (R-918). - Riveted left rudder stiffeners to left to left ridder skin (R-915s to R-901-L). - Attached left rudder skin to rudder skeleton. - Final drilled all rudder skins to spars and ribs. - Drilled reinforcement plates to rudder spar (R-902). - Drilled counterbalance plate to skin and ribs. - Pre-Drilled leading edge holes. - Drilled horn brace to bottom rib holes. - Attached and drilled botton attach strips. - Attached and drilled trailing edge wedge to skins. - Disassembled entire rudder for deburing. - Deburred all holes in rudder skeleton.
Riveted Left Rudder Stiffeners to skin.
Attached Left Rudder skin to understructure for final drilling.
