Brief Description: Rudder - 03 - Fabricated Right Rudder Stiffeners
- Fabricated stiffeners for Right Side of Rudder. - Marked and cut to approximate dimensions with straight cut sheers, the ground it down to the line with a Scotch brite wheel. - Deburred and smoothed all Right Rudder Stiffeners. - Clecoed stiffeners to skins and match drilled. - Deburred stiffeners and skins. - Dimpled all stiffeners. - Washed stiffeners and prepped for primer. - Primed stiffeners.
Right Rudder skin stiffeners.
Final drilling stiffeners to skin.
Right Rudder stiffeners drilled, dimpled and ready for prime.
