Brief Description: Horizontal Stabilizer - 06 - Right HS Section
Basically performed the same tasks as the left side but on the right. They go together the same way but faster because now you know what to do and how to do it. - Marked all 4 holes on center rib (HS-405) before assembly and didn't like the location of where the holes ended up on the attach / reinforcement angles. They turned out better when I drilled the pilot holes after the assembly was put together (on the left side). Lesson learned for the next RV I build. Shhhh don't tell my wife!!! - Assembly is ready for deburring, dimpling, prepping and priming.
This is the Left Side but it looks the same. More child labor!
How easy are these kits to build...Well, she's 9 years old...Do the math!
Forget pneumatic Cleco pliers, this is how you keep from getting soar.
