Inside and outside flashing was straight forward. Making the bends in the inside flashing and angle was done as described in the assembly guide. It was a little tedious but worked OK
Big problem with the release handle. The photo assembly guides say to drill a 7/8' hole in the flashing 35mm up from the bottom. I did this only to find that the tangs on the release handle would not allow it to rotate as it jammed on the steel canopy side frame. Had to grind all but about 3mm off the tange. There was just enough room to drill a hole for the release wire. The original 7/8' hole shouid have been drilled 45mm up from the bottom of the flashing.
