Brief Description: Balance Elevators - Heavy Fabric
Balancing elevators. Using 1.1 lb at 7.5" behind hinge line since using heavy fabric.. Russ Erb used 1 lb @ 7.5 inches. Started with left elevator. Installed trim tab. Trim tab hinges a little tight with paint. Reduced pin diameter on drill press for better fit.
