Been off a while. Family illnesses. Also having trouble being motivated in heat and humidity. Starting to get up early while temps in 70's to get welding done with out sweating all over the tubing. Welded out ouboard trim drive horns in place. Welded 10-32 nut on end of 5/16" x .028 tube for trim drive rod. Bend trim drive rod 30 deg at 16 9/16" from aft end (nut).
