Brief Description: Starting on Elevator Trim Tab Drives
Welded drive horns on Trim tabs. Working on trim drive aligment. Cleaned all parts and prep for welding. Tacked elevator trim tab horns. Tacked inboard trim drive bushings. Removed Elevators and HS's. Welded out trim drive bushings in HS's. Finished weld on down Elevator stop and rudder stops.
