Brief Description: Finished more parts for final tail assembly
Using the temporary aluminum links, made the 0.125 4130 tail wire links. Made the T-9 tubes and welded to elevator horns. Only drilled the hole in the T-9 tube 1/8" to be able to final drill to 3/16" once positioned. Hoping for a better fit.
