Cut, fit, tacked, & welded left elevator trim tab. Left elevator done except trim tab linkage plate. Also need tab(s) for lead balance weight.
Completed welding of Left Elevator! One more part done.
Started on right elevator. Cut, fit, and jigged up parts. Cleaned parts and jigged for final welding. Tack welded one side except for T-1 diagonal bracing and trim tab hinge tube.
