Brief Description: Prep for installing ailerons/flaps
Bolted right wing hinges with rod end bearings installed. Orinally though bolts for flap hinges would be AN4-12. Those are too long. All hinge bolts AN4-11 single thin washer. Drilled out out pop rivets to remove top gussets on right wing flap and aileron.
