This is the original version of the instrument panel.
This was the first fit up and have a few issues:
1) Not satisfied with the mounting of the GRT Mini and Sport EX EFIS's. Have a perference for the "flush look". This will require eliminating the upper panel that spreads across the top. Wasn't really happy with the finish on that panel anyway. Need larger opening in the vertical direction for the recessed mounting angles.
2) The location of the USB hub doesn't provide enough clearance between it and the top of the control stick.
