Spent the last handful of days preparing and priming the right wing.
Tried several solvents, including Glue Gone, to remove adhesive from plastic sheeting that had been on the wing for a really long time. Settled on a "cocktail" of xylene (lower evap rate) and laquer thinner using a scotch-brite pad.
Acid etched and coversion coated right wing.
Primed right wing with PF EP-420 Epoxy Primer. Estimate used ~30 oz (~1 qt) epoxy primer base to spray right wing with light 1st coat, followed with two medium coats. The catalyzed epoxy primer was reduced 3:2.
