Mike came by to help put the Hartzell CS HC-C2YR-18F/F8477/SM19.
Decided to go with 5/16" Hartzell spacers without washers. This should be close to 1/4" spacer (Vans part #S-604) with washer that Vans specs for their composite spinner.
Mike got me helped with the lifting and geting the prop bolts started. I continued and found some problem with tighening the prop flange. Didn't do enough reading again! It apprears that the engine prop flange is a "K" flange and I have an "R" prop hub. Russ Erb discussed this on his CD, I just forgot.
Had to remove the prop and rotate it one bolt. Got it on correctly.
