Bear with Me!
Date:  4-9-2018
Number of Hours:  6.50
Brief Description:  Start on cowl right door
Made template for right door. Discovered that I had ordered the wrong piano hinge. I have the the cheaper rolled hinge. Bob spec'd out the more expensive extruded hinge. I've come to an understanding that Bob wouldn't spec the more expensive hinge without a good reason.
Using the template, cut the door blank from .025" sheet.
Ordered the expensive extruded hinge.
