Brief Description: Rework of Aft Wing to Fuselage fuel Connections
Well, the problem with fuel selector valve has slowed me down and has me regrouping. This will in the end be a great thing. Since I couldn't do the quick flow test because of the bad selector valve I've decided to rework the aft fuel tank connections to the fuselage. My first attempt resulted in a crimped tubing and I was doubtful I was going to get the needed fuel flow test.
So using a special method for bending a short run on a bend got better results.
