Loosened adel clamps and adjusted the routing of the forward vertical fuel lines inside the boot cowl. Moved to the fuel lines aft to get better clearance in the area of the side cowl vents. Also adjusted the fuel lines for better clearance from the boot cowl edge where it exits at the top of the boot cowl.
