Bear with Me!
Date:  10-23-2018
Number of Hours:  7.00
Brief Description:  Installed fuel lines
Installed 3/8" fuel lines prior to covering.
NOTE: Fuel lines were reworked at the inlet and outlet of the fuel valve. More direct routing was made on the inlet sides of the valve to provide needed clearance with boot cowl, The outlet of the fuel valve was modified with 45 deg bends instead of the 90 deg bends to provided clearance with installed tunnel.
