Drilled holes in stringers and cut to final length.
NOTE: Following OTR and not per plans. Wanted to add aluminum access panel on bottom of aft end of fuselage for inspection, maintenance, and housekeeping. Things just end up there and wanted an access point. Made .050 4130 angle to serve as panel mount/fabric termination. Tacked angle and stringer clips in position. Drilled 5/16" holes in angle to allow any water to drain.
