Making brackets and tabs for vertical door formers.
OTR - "off the reservation" - NOT TO PLANS
I'm not comfortable with the short tabs securing the aluminum forms. I've decided to use a combination of tabs and U-brackets. I'm using .040" material. Brackets are 3/4" wide with 3/8" legs bent in brake. This is the size that works in the brake and gives full bend clearances.
