Started on .100" control pulley brackets for bottom of fueslage. Had to make 3 brackets to get two good ones. I made mine 1/8" longer than shown in plans. First to get just a little more clearance for the flap cable at the landing gear fitting and second to not have any interference at the top of the pulleys that other scratch builders have had.
Initially I thought I had bent the bracket too wide because there was a bit of slop in the pulleys on the bolts. After referencing Paul Mingela's Kitlog site I reconsidered. Need to leave a little sclearance for paint and what that don't take up a little washer will. Thanks Paul.
