Brief Description: Weld punch list and start on flap lever
Welded out all fittings that had been previously tacked. Lot easier now that fuselage back in rottisserie. This included the elevator bellcrank, control stick mounts, bellcrank arms on control stick, and lower brake cylinder mounts.
Had to grind out weld on bellcrank bearing ring and reweld. Got a little stiff.
