Brief Description: Fab landing gear attach fittings
Glued templated to sheet material and pre-drilled. Then rough cut on bandsaw and grinded/sanded to final shape. Bent pieces on jig. Drilled, cut, and sanded to final shape remaining pieces.
Completed all gear attach fittings except for two front fittings at STA B (forward gear leg attach point). At least two previous builders had to remake these pieces and add a little material for final fit. This is due to the bend in longeron forward of STA B. I'll wait till test fit with the first tow and cut out these as needed.
