Mike M coached me through the riveting of the Left Wing. Took a while to work through the process. Could not have done this without Mike's experience and help. He did the bucking and I had the the rivet gun which was the easier of the two jobs.
Learned two things on the first wing:
1) I was putting too much downward force on the rivet gun. Does not need excessive force on the rivet gun.
2) Should have laid out, drilled and dimpled the cove area at the aileron. I realized that this needed to be done prior to riveting down the top skin way too late. The drilling and dimpling of the skins and short ribs in this area is much easier to do prior to riveting
