Bear with Me!
Date:  12-6-2019
Number of Hours:  5.50
Brief Description:  Rudder Pedals and Brake Lines
Installed brake reservoir on cabin side of firewall to eliminate another penetration and the additional fittings that woudl require. Plan is to use plasitc tubing from the reservoir to the master brake cylinders. Hoping this will provide a visual clue to low brake fluid level.
Only installing brakes on pilot side to save weight.
