Brief Description: Set Wing Dihedral and Start Wing Struts
Set dihedral for both wings using water level after checking fuselage for level. Set end of wing at 2 15/16" above inboard end. All measurements taken at main spar.
Measured spar bolt holes from fueslage to wing. Left wing 82 3/8" - 3" = 79 3/8" spar length Right wing 82 5/16" - 3" = 79 5/16" spar length
Cut left spar to 79 3/8". Started to squeeze ends to fit 1 1/2" end fitting.
