Bear with Me!
Date:  2-8-2016
Number of Hours:  4.00
Brief Description:  Adjustable wing supports
Due to the fact that I do a lot of my work alone. I thought I should devise a system that would allow me to move the wings without a lot of needed assistance. I also didn't want to spend a lot on new roll around frames. I repurposed the jig tables. John Bread came by and helped finish the wing supports, move the jig tables in position, and lift the wings onto the supports.
The supports have a 3/4" conduit base that is attached to the table with 2x4's drilled with 1" holes and conduit straps. Conduit is a cheap commodity that can be useful. Each stand support has 12" of 3/4 x 10 TPI threaded rod with washer and adjustment nut. The top end is heavy wall 1" square tubing which provides a nice snug fit.
The tables are heavy but I can move them by jacking with floor jack and sliding a furniture dolly under. Seems to work pretty well so far.
Got fuselage mounted on 12" tubing supports.
