Brief Description: Rudder Spring mount and firewall tabs
Working on rudder spring mount. Details not specified in plans. Avipro uses a tab on the outer vertical tube. Best I can tell, Bob and Eric used a 1/4" piece of tubing.
I decided to uses a angle of .063" 4130. This gives me a little more options for matching the return spring length. Welded angles in position.
Made 7 .063" 3/4" x 1" tabs for firewall. Welded in position on firewall tubes.
