Bear with Me!
Bearhawk
Mounting Rudder Pedals
Finished cutting and shaping .062 plates for rudder pedal mounts. Welded in a 4" CL per plans. Left extra 1/2" for floorboard attachment.
NOTE: Remove any bolt in lower engine mounts before welding in rudder pedal mount plates. Interference fit. Had to grind bolt heads to remove.
Had to work on pilot side bearing for a while. Got stiff when bolted down tight. Had to straighten out slight bow in bearing foot.
Remove any bolt before welding in plate!
Marsh Tracker Home
Bearhawk Home
3164
Boot Cowl-Tunnel
CS Prop
313
Engine Cowling
Fabric
Flight Controls
66
277
Formers/Stringers
442
Instrument Panel
Prime-Paint
R&D/Education
Vans FAB & Air Scoop
Weight & Balance
Windows & Doors
Windshield/Skylight
465
