Brief Description: Poly Fil right wingtip and strobe mount
Applied Poly-Fil to right wingtip trailing edge and joint seam. Installed right strobe mounting plate inside with Poly-Fil. had to do work inside so Poly-fil would cure in a reasonable amount of time. Too cold in the shop.
Started drilling and dimpling holes for tinnerman anchor nuts on right wing tip.
