Bear with Me!
Date:  9-3-2012
Number of Hours:  2.50
Brief Description:  Prep for installing ailerons/flaps
Bolted right wing hinges with rod end bearings installed. Orinally though bolts for flap hinges would be AN4-12. Those are too long. All hinge bolts AN4-11 single thin washer. Drilled out out pop rivets to remove top gussets on right wing flap and aileron.
Aurora Part Number
Aurora Part Number
Rod ends with temporary nuts.
Top gussets removed.
