Made short tensioner straps for fuel tank. Drilled hole for filler neck. Used method described in Avipro manual using a 1/4" drill inside of line and then smoothing with sanding wheel. Pretty satisfied with results. Made new template for drilling holes in inside ribs for fuel lines and gauge glass. Installed straps.
