Brief Description: Start of Left wing fuel tank cover.
John "Bread" came by to help. He worked on drilling and countersinking holes for the fuel tank bottom cover. I worked on the final inspection plates for the Left Wing. Got a lot done.
Next time, may consider drilling and installing inspection covers first. The last one located directly over the rear flap drive mechanism has limited access. The flap torque tube runs pretty close to the bottom skin. Tough to get rivet squeezer in there. Skin is thin and flimsy in that area making it difficult to use a rivet gun without behind things up pretty bad. Gonna have to disassemble flap torque tube and pull it out, rivet, then re-install.
