Brief Description: Aileron bellcranks and outer hinges
No pics. Mounted outer aileron hinges. Spent time on aileron bellcranks to anticipate any cable rubbing. Discovered that my welding got to close to the hole for the cable to mount on the bell crank. Had to grind some of my welding away to make clearance. Good news was that when grinding it was solid which means I am getting good penetration on my welding. Order my wing skins.
