Brief Description: Pulley brackets and Flap push rods
Put another coat of paint on the flap torque tubes. Mounted pulleys to the web splice area using the brackets I just made. Did some test fitting using some nylon rope to check for alignment. Started working on the flap pushrod assembly getting it worked out and the bushing made just right. Still need some time perfecting this component.
