I put a final coat over all the aluminum of the wing assembly before mounting all the steel. Lots of primer had beed scratched off or where I had modified or cut portions the deburing took off primer. So this final coat was to cover anywhere where two parts would be touching.
Final coat before final assembly
1 thin final coat to cover the scratches of assembly.
