Brief Description: Mounted hinges, Installed some rivets
Really just having to finish up several small things before I get ready to skin the wings. I mounted the now painted hinge mounts to the rear spar. Then decided to put in some of the rivets I had skipped during spar assembly. I skipped them because they were around a location where a bolt would go and I wanted to avoid putting them in the wrong spot. Now it was time to put them in. Ethan came out and I let him set several of the rivets but we had to drill out a few from his learning curve. That is why I am building a plane anyway.
