Got most all the holes in the sparcaps drilled today for spar number 2. Splice plate is in place and ready for finishing. Got the 4130N steel today to make the brackets that the struts will mount to. This is what I was needing to finish the splice plates. Discovered I made a mistake on spar number 1 today as I had put the splice plate on 180 degrees out. Still trying to figure out what issues this is going to cause and how much stuff I will have to replace to fix this error. This was a bonehead mistake.
