Brief Description: cowl air inlets, Garmin updates
More grinding and sanding on the upper cowl air inlets. Made the foam seal for the prop governor. Set the top cowl on the plane, marked it, then used clear RTV to glue the seal in place. Drilled then countersunk the holes for the left side inlet seal then installed the seal. Made a couple of attempts to install databases on the G3X touch and GTN but no joy. More research needed...
