1st engine start today! Lori and I calibrated teh right fuel tank with similar results as the left. Flow rate in flight level attitude was 45 g.p.h. After calibration we pumped 13 gallons out of the right tank and put it in the left then wheeled the plane out front. Blocked the wheels, tied the tail to Lori's jeep, and positioned the fire extinguishers. Engine started immediately and ran strong. Performed mag check, cycled the prop, checked idle speed then shut down. Fuel flow meter reads "0", so I've got another fun troubleshooting job to do.
