Adel clamps arrived today so I cleaned up the right side spark plug wires. Cleaned up some loose wire. Installed hose between fuel pressure line and the throttle cable to prevent chafing. Put a wire cover on the Slick magneto and re-supported the oil temperature wiring. Secured GPS coax in the aft section, vacuumed everything, then installed the fuselage bulkhead cover. Installed all floor panels and pulled four year old tape off of longerons. Tried to install Crow seatbelts, now waiting for parts from crow (needed larger hole in D-link). The interior arrived last night!
