Installed the CHT sensors on the engine block. Torqued front spinner bolt to 70 in/lbs and safety wired them. Installed rear left and right baffles, left needed minor trimming at block centerline. Installed one clamp pair on left side of engine mount. Purchased a 6'32 die and then cut and threaded the stainless hinge pin to make baffle rods.
