Put together the right front baffle, had to cut an epoxy airbox as part of baffle. Finished it and then did RTV stripes on the forward baffles. Worked a bit on cowl edge trim then reworked some of the epoxy ramps on the upper cowl. Placed the heat sheild on the lower cowl.
