PreKote and primed all baffle pieces plus aileron pushrod tubes. Made shims for oil door. Aircraft Spruce order came in so installed seal trim on canopy, tightened the screws in "zone 1", and riveted the rub strips in. Drilled 3 bottom screws in lower cowl, it needs a bit of trim still on the right side.
