Greg's RV-14A
Date:  11-26-2020
Number of Hours:  6.00
Brief Description:  flaps, wing electrical
Thanksgiving Day! Hung right flap and connected pushrod. Used Steins method of micro molex pins and heat shrink to connect OAT probe. Used butt splice for pitot heat ground. Tested - pitot heat good, OAT fail. Troubleshooting found blue/white wire shorted to ground at instrument panel connector (my bad). Repaired, reconnected, all is well. Finally have OAT reading and pressure altitude available. Connected AOA and Pitot air tube then tidied everything up. hung left flap and connected pushrod. Good day all in all.
left wing OAT connection
left side finished
left side finished
